Network Cable Unplugged (but it isnt!!)
30 May 2004
i keep this brief, i run a simple 2 connected pcs with crossover cable
reason obviously so my other pc has inet connection
it all works nicely
now i brought in another pc and i JUST wanted to test it, (i dont want 3 pc's connected)
so i connected the new pc up which is almost identical to my other pc but has a linksys LNE100TX ethernet card, but it says network cable is unplugged, so i cant proceed with the network wizard!!
1) now i know the cable works because it works with the other pc so it cant be the cable !!
2) i have another linksys LNE100TX ethernet card which i tried, and no luck !
3) i tried different pci slots, still no luck !!
(all pcs run xp)
i just dont get it
anyone got any ideas? cuz iam all outta them :)
cheers people
trav.
are you using a patch or crossover cable?
If it's a patch i would guess the problem is that the network cards in machnes 2 (old)and 3 (new) don't have the ability to autosense that it's only a patch and correct for it.
It's probably working with machines 1 and 2 (assuming you are using the same cable for them) because machine 1 has a NIC that can auto correct for the cable type.
Try connecting machine 1 and 3.
cable unplugged can mean just that, but it can also mean the cable is damaged (you've already tested it), the wrong cable is being used, or the device at the other end isn't responding as expected (either due to the wrong cable being used, the device being faulty, or being turned off - my PC gives a cable unplugged if i turn off the router;)).
thanks for the reply matey
iam using a patch cable
now my setup is as follows
PC1 has the internet connection, and has an inbuilt nic on the mobo
PC2 also has a NIC built into the mobo, and it works fine when connected to PC1 via the patch cable
now i remove the cable from PC2 and plug it into PC3 and get the unplugged message in taskbar
PC3 is using the linksys Card, iam guessing the linksys card doesnt like the patch cable.
iam going to try and get another brand of network card and test it out
however when you said
"don't have the ability to autosense that it's only a patch and correct for it."
is there a way of fixing that? or is the only option to get a crossover cable
or get another ethernet card that does support patch
many thanks
i just realized theres no light on the back of the linksys card
even when i try another linksys card, still no light...
iam guessing thats a bad thing :)
You have a few options:
1). Buy a cheap switch
2). Buy a crossover cable
3). Buy a patch to crossover cable adapter
4). Buy a new network card
All options are dirt cheap and I'd be inclined to suggest the switch route as this will provide the option to add more PCs at a later date, something you don't need now but it could prove useful in the future.
hey Phemo,
funny you just said that
i went out brought back a cross over cable
tested it, still saying cable is unplugged :(
then i got another network card this time by realtek
still the same thing !
tried the patch cable again, still nothing
i also went into device manager, set both to full duplex still nothing, same with half duplex and they were originally both on auto sense, so i know that doesnt works anyway
hmm i got one option left which iam going to try out
the pc that has the internet connection, thats using an integrated ethernet card, iam thinking about using the linksys nic or realtek nic on that, then using the spare linksys card on the other pc
ill post here the results
fingers crossed :)
hey Phemo,
i tried the above, didnt work
oh well ill buy a hub switch, even tho i dont need one because iam never gonna run more than 2 pcs here
but if it corrects the problem, then so be it
if theres anything else that i might of left out, let us know, thanks for the help people, tis a strange one, but thats pcs for yas :)
laters
