Network cabling, faceplates and adapters.
31 May 2009
I wish to do a little network tidyup and am pondering the best aesthetic.
Currently my BT master socket is by the fron door, beside it is the white box infinity modem and the bt homehub3. My home server sits in a small cabinet below these devices, connected by network cable. Wireless signal around the house is excellent from this position, but the two main PCs are currently wired, having no internal wireless cards. I like my main PC being wired.
This means I have long network cables running from one side of the front door, along the floor into a front room/office space. Trip hazzard etc for the young one. That floor is tiled, large tiles, not easily lifted, and look well.
I am considering running two cables from the master socket area, around the doorframe and into the office/front room. Easily enough done, but what i am wondering is if I was to run these cables, and at each end instead of directly connect to the computers and the homehub, to instead terminate each with a network box, with a cat 6 faceplate, and from that take a shorter network cable to eahc machine, and at the other end to the homehub.
It would mean if I ever move things, or shift around, the boxes can stay in place and leave things neat rather than having network cabeling end hanging freely off the wall.
Will this work okay? what items would I need to terminte in the boxes etc, will I lose signal strenth or gain interference with extra connections etc?
I just finished putting my boxes on the wall, I have an area in the centre of the house where all my networking is going to be coming from. Just a couple of runs but they go from centre of house, to outside, to downstaires, to inside, to phone point.
Can you [OP] run a cable the same way I did from inside > outside > inside the house to which you could put genuine faceplate installations in and make it trip hazard free and nice n tidy?
Deffo go wired rather than use powerlines if you can, it's easier than you think. I did my house ealier this year and did a little writeup on AV forums:
http://www.avforums.com/forums/networking-nas/1606985-my-home-network.html
Dave
We have the same switch I think. HP Proliant. I did mine a couple of years ago using a guide by a member on AVF too. In fact here's the link to the guide I used:
http://www.grimroper.com/news/2010/News_100220_Get_off_our_LAN_Part_1.html
edit - I still find this the best guide on the net, especially for those who need to route cables going out of the house and who need to improve wireless coverage.
Thats an intersting suggestion, it would mean hiding cablingunder the front doorstep in my case, and also then running under carpet in one of the rooms, which may or may not be appropriate.
We will get that room redone, but I was thinking more 12 or 18 months away.
you can always use flat cat5e ethernet cable if you're hiding cable under the carpet, you don't get any bulges that way.
