Very common, don't worry. Card is fine.
Make and model of router? ISP? Any other laptops/PC's connected to network and via what? E.g. Ethernet or Wifi?
Does this PC in question work OK if connected to the router via an ethernet cable? If not... it's an internet issue and not a software/hardware/network card issue.
If it does connect. Log onto the router using it's I.P address. Simply type it into the address bar in your browser. To find the I.P.
Open CMD, type "ipconfig" Default gatwat: 192.168.x.x.x.x That is your routers I.P.
Log in. Password and Username are usually on bottom of router. If not. Defaults are usually, "admin" "admin" / "admin" "password" / Orr "admin" "leave blank" (Don't actually type "leave blank obviously*.)
Once in. Find wireless settings. Change encryption to WPA2-PSK if possible, If not. WPA-PSK. Change passkey to something memorable. Any password really. Also change the SSID to something else, (street name or whatever)
Now in start menu, type "configure wireless networks" Open it. Once in... delete all previous wifi networks.
Now rescan for networks using the tool in system tray. Find your new SSID. Connect using your new passkey you just made.
Now try pinging google. In command prompt... type. "Ping
www.google.com"
If you don't get a reply and you get a timeout. Log back into router and confirm all ADSL settings are entered... username and password etc. If not. Contact ISP for details.
P.S. Don't forget to save settings in router config after changing them and switching pages.
God I hate wifi troubleshooting. I always get it done in the end using these steps (I've done it tooooo many time) It can be so frustrating... especially running around the house resetting routers and ripping phone wires out.
Failing all this. Call someone local who knows what they're doing.
Hope all helps.
Ohhh.... Settings wont be wrong or mis matched with regards to AES or TKIP as if you scan and connect via the dialogue box. Windows configures this for you and recognised the encryption used on the network. It doesn't get mixed up and use the wrong one. Only if entered manually. Which is a waste of time really as the scan feature works fine!
Also make sure "UPNP" is enabled in the routers settings. If ticked this will eliminate any DHCP issues. Most routers are configured to spit it I.P. automatically and very rarely this is turned off. If it's connected to the network, just not the internet. It's already received a local I.P. and again... not the issue.
I do this as a job btw *Sighs* Should have stuck to judo coaching! A lot less stressful.
