Hi
My house is hardwired it has network sockets on the walls they then got to a cupboard were the ends of the Cat5 wires are
it has been working fine for about 1 year then it started to get random disconnections and slow speeds
on checking the wires the end that have the rj45 connectors have play in them ie will move left and right within the rj45 plug.
is this normal?
do i need a better rj45 plug?
would i be better taking each wire to a socket and then using patch leads?
HELP!
is this normal?
HELP!
