Hi,
I have been given a Compaq Presario SR1000 from a family member that I wanted to use as a general use PC at my business, but before giving it to me, the original plan was to give it to someone interested in buying it.
So I used Darik's Boot and Nuke to wipe the hard drive of all data, then plans changed and that guy doesn't want it anymore.
So I've installed XP on it and plugged in an ethernet cable into the port on the motherboard, but on the network section of control panel and under network adapters in device manager, only the 1394 connection is showing up
Any ideas?
Hope you can help!
EDIT: The light on the ethernet port on the motherboard is flashing. Also just tried to download a driver from the HP site, got it (maybe for a slightly different model) but when I go to install it says that drivers are already located on the C drive (there is a folder here with LAN drivers) and to install them through device manager ... But if the device isn't under network adapters how do I install it?
Any ideas?
Hope you can help!
