Hi all,
New build house to which I am adding POE CCTV. I will be running the cables in to the attic space. Running cables between floors is proving problematic, but the attic gives me good freedom of movement - I can then keep everything within there or, go through the ceiling in to the airing cupboard. So I will have:
CCTV PVR
POE Switch
NAS
I can put them in the attic, which is currently averaging about 6.5 degrees and 88% humidity (no idea what it would be in the summer), or the airing cupboard which is averaging 27 degrees and 31% humidity. Max recorded is 28 degrees so it seems stable.
From a purely preferential point of view, I would keep them in the airing cupboard - I have no permanent loft ladder so access isn't great. But do you think the airing cupboard is too hot? It is quite large, approx. 2m x 1m, and has no ventilation. I couldn't add ventilation on the walls or door due to layout and materials, but I could create some kind of ceiling vent in to the attic space above.
Thanks!
Wings
CCTV PVR
POE Switch
NAS
Thanks!
Wings
