- 14 Mar 2005
- Cornwall
finished
Beansprout said:Assignment?
Beansprout said:You're allowed to ask for help, but giving the complete problem and asking for a solution aka doing your homework is not allowed.
Try stating what you've done so far, and specifically what you're stuck on, etc. If you're totally stuck, ask a classmate or lecturer![]()
Lex said:why cant you just tell him? whats *** big deal even if you do do his homework its a forum we're not 'teachers' we discuss
tonyyeb said:Because the student will never learn if just given the answer. It is called ethics. He gets a grade A for work that he hasn't done.
The UK government are trying to crack down on this in a big way.
Because I haven't worked the answer out - I have my own stuff to revise forLex said:why cant you just tell him? whats *** big deal even if you do do his homework its a forum we're not 'teachers' we discuss
Si MPS said:Thats a bit of a high horse you're on their mate, some people need a bit of help sometimes and i can tell you from someone who does a networking degree, a lot of the lectureres are not helpful at all.
Curiosityx said:I would use VSLM and as there isnt a linear distribution of hosts in each subnet assigning all subnets a /27 mask would waste a lot of address space.
Using a network of 192.168.1.0
/27 for the largest segment - 30 Hosts per subnet, 4 Subnets
/29 for the smaller segments - 6 Hosts per subnet, 32 Subnets
Im thinking along the lines of Cisco whether this is what your studying im not sure. Also i dont know the brief there may be a need for future expansion as such masks allowing a larger number of hosts would be needed.
tonyyeb said:A bit of help is fine....
