So, I need a little help here.
First off, I have two internet connections (one for room A and one for room B) both use different routers and both have LAN switches connected to each router but the switches aren't connected to each other.
What I want to do is set up a home server in room A that I can locally access from room A and B. Access from the same router is easy enough, but I need help on how I would do it from room B.
Anybody know the solution to this?
TIA
TIA
