Hi all,
I am currently in the middle of rewiring my house as part of a full renovation before I move in.
One things I want to do is have two network points in each bedroom and behind the tv in the living room, giving me a total of 6 sockets.
Now I was planning on just leading these back to a 8 port switch but I am not sure where is best to locate the switch. I was thinking about the same small cupboard on the wall that the fuse box is in since all the floor boards are already up leading back to that so it would make a easy job. But I have read electrical cables can cause interference with network cables and cause errors due to cross talk?
I dont see the point in a patch panel since I don't have many connections, am i right in thinking though if all cables go back to a switch this will create a network. So if i plug my router into one of the RJ45 sockets in a room it will provide internet access to the full house?
Also what distance should the network cables be kept from the electric cables or should this not a issue with CAT5E cables?
Anymore advice would be great and other peoples experiences doing the same thing.
Thanks, Sam
Thanks, Sam
