17 Sep 2008 at 15:41 #1 Tuffers Tuffers Permabanned Joined 5 Aug 2008 Posts 95 Hi guys I am looking for a description of the Client Server(s) communication at IP level during a Windows Logon procedure. Any help or links would be great
17 Sep 2008 at 16:42 #2 HarryPainful HarryPainful Permabanned Joined 5 Jan 2008 Posts 4,123 Spoon fed much?
17 Sep 2008 at 16:55 #3 PaulyD PaulyD Soldato Joined 24 Mar 2008 Posts 4,652 Location High Wycombe Port mirror a switch or get a hub and run wireshark on another PC - rather than get a description actually see what happens..
17 Sep 2008 at 21:44 #4 Tuffers Tuffers Permabanned OP Joined 5 Aug 2008 Posts 95 HarryPainful said: Spoon fed much? Click to expand... Well as you haven't supplied an answer I'm guessing any searching you did actually do returned the same lame results that I found. PaulyD said: Port mirror a switch or get a hub and run wireshark on another PC - rather than get a description actually see what happens.. Click to expand... Thanks, great idea
17 Sep 2008 at 23:00 #5 GhostlyPea GhostlyPea Soldato Joined 30 Dec 2004 Posts 4,681 Location Bromley, Kent I was going to suggest wireshark, best I can come up with - Pea0n
