Currently the network at work is slower than a turtle on dope, in the office we have roaming profiles and local profiles, but even when we're not accessing things on the network (as far as i know our profiles only update on the server eery time we log off) we get random 10-20 second pauses where we cant do anything, normally on start menu etc (note: start menu doesnt load from the network, its completely local)
all 3 pcs in the office get these pauses at the exact same time and return to normal at the exact same time, the cabling here is REALLY weird and stupidly done and its all getting re-done into a ring network over the summer but until then im looking for suggestions to stop these pauses
things like registry tweaks to make the network stop pausing my machine, any server side things people can suggest (difficult i know as you dont know the network im on) things i could check for in the start menu (i havent done much with roaming profiles to know where to look for where bits are loading from really) anything anyone can think off, dont mind how small or how strange something might sound, if theres a possibility it could stop the pauses in our office that would help a great deal
currently we're so annoyed with it we're tempted to wire ourselves straight into the same switch the servers go into
but we'd prefer not to because we've got a lot of other things to do
this post probably makes me sound a bit like a network user without a clue but i just dont really know how to explain the problem we're having, i know this network like the back of my hand so dont worry how complicated your ideas may be
.... the veins in my hand are easier to trace back than the cables of this network though
