Hi,
I am looking for suggestions on a good network switch which will be installed in the loft and needs a minimum of 16 ports (24 port switches also considered) PoE ports a plus. It will be installed in a wall mounted 9U rack with all the cables running into the loft from the single floor property. The loft is insulated but will still have some range in temps throughout the year. Ideally it will be future proof with the PoE which would allow me to add CCTV easily to the network.
Any recommendations welcome or if you have had a bad experience with any switched please also share.
Many thanks,
Dan
Many thanks,
Dan
