Network monitoring
SMN
SMN
2 Nov 2008
The ether
Hi chaps,
Just doing a bit of research on network monitoring / NPM and wanted to gather thoughts on what you guys think is needed for a top NPM. So far i've come up with:
Ping checks
Interface throughput (port monitoring)
SNMP polling (OID's/MIB's)
SNMP Traps
*flow monitoring (Netflow/sflow/jflow)
Syslog monitoring
Is there anything else that i am missing that you can think of? Any input would be much appreciated.
Thanks,
Sam
There are more things needed to monitor than what could be listed here realistically.
Whats your budget
Number of nodes
Type of modes + manufacturer
That's a good place to start.
- GP
Whats your budget
Number of nodes
- GP
Thanks for the reply. I'm doing this more as a market research project than as a punter - i.e. other than the above, whats "cool" or even useful in network monitoring.
Ah right. Erm. Well as before there's to much to list which also depends on the vendor. If you're staying vendor neutral then also consider things like
- Discards
- CRC errors
- Monitor BGP sessions
- Interface resets + uptime
- Node CPU/memory
That sort of thing. Are you focusing around routers, firewalls, switches, APs? Or generic?
- GP
- Discards
- CRC errors
- Node CPU/memory
- GP
Totally generic really although probably more bias towards Cisco than any other (market leader by a way for one, and i used to work for them for two!).
At the moment I'm doing product strategy for my company - having just released a netflow product i'm doing research on kind of... where next really. Deciding whether to go after the "other flows" (sFlow/jFlow?) or look at syslog monitoring instead, etc etc.
Some of the metrics I've used in the past (trying to keep things very vendor-neutral)
IP Interfaces
Physical Interfaces
ICMP/SNMP/SSH
TCP Open Connections
Current TCP Connections
TCP Errors and Failures
Total Processes
Total Memory
Uptime
Load Average
Throughput (port monitoring)
Percent Errors/Discards
ICMP response time
SSH response time
CPU Usage
