Network novice needing advice on home server
24 Sep 2013
York
Afternoon all,
Finally decided i needed to take the plunge and sort out a home server/NAS box rather than chopping and changing between the 5 external hard drives that are cluttering my room at the moment.
Looking for some advice about the basics and what would be the best solution for my needs.
Basically:
Need a decent amount of storage, Got all my blurays backed up on externals at the moment along with music and also the extended families treasured home videos and photos!
Would like to set up a home server so it's accessible remotely so that parents and brother can get at the family stuff from their own computers.
Think those are pretty much the only essential requirements but would be nice to be able to stream media to different parts of the house as well so that girlfriend can watch her terrible rom coms without subjecting me to them as well.
Budget is not an issue really, would rather get something quality set up that will last me and i can upgrade in the future. Been looking at hard drives and i gather that the Western Digital "Reds" are the weapon of choice in terms of server drives? Is this correct? If so then i'd be looking at 4 x 4TB ones of those to cover the storage side of things. Apart from that i'm after some advice as to what i should use to hook all that together and provide the remote access capabilities and streaming.
Any ideas folks?
Thanks for the link Wonder, I'm currently tempted by a Synology NAS box as it looks like that'll do the things i'm after. Just busy investigating the software that comes with it.
Sounds like a perfect excuse to get an HP Microserver and install XPenology on it. This will allow you to use Plex for media streaming (also has it's own built in media streamer but I prefer Plex), allows remote access and also lets you set up access restrictions so your family can only access the files you let them.
This is essentially what my server is:
YOUR BASKET
1 x TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34GM1600HC11DC01) £32.99
1 x OcUK Value Imp MicroATX Tower Case (500w PSU) £31.99
1 x Intel Celeron G1610 2.7GHz (Ivybridge) Socket LGA1155 Processor - OEM £31.99
1 x Foxconn H67M Intel H67 (Socket 1155) DDR3 Micro ATX Motherboard £29.99
Total : £138.66 (includes shipping : £9.75).
Plus Windows Home Server 2011 (which OcUK no longer seem to stock) and hard drives of your choice.
(Although the CPU says "OEM", when I purchased one of these a few weeks ago, it was in a retail box with heatsink/fan...)
I have more hard drives, as well as StableBit DrivePool to provide one large storage pool (currently 8TB across 3 drives) with the ability to easily add or remove drives.
This stores all my data, does automated backups of my PCs in the house, and with a TV Tuner card provides live/recorded TV across my house, and runs MySQL, XBMC, apache, FTP server and anything else that I need access to 24/7.
The motherboard has 6x SATA ports for plenty of hard drives, and the cheap case holds it all just fine - an HP microserver will limit you to 4 drives, and give you very limited upgrade options - with the above, you could drop any 1155-based CPU into it all the way up to an i7 - providing you with plenty of CPU power if you need.
