Network Points
27 Oct 2003
hi i was wondering does anyone know where i can get a load of network points from good quality which have all the bits, back plate, front panel and modules. I would prefer the back to go into the wall oppose to sticking out.
some nice CAt 6 cable would be nice too
I would imagine anywhere that sells that stuff (i assume you mean faceplates etc) would likely be a competitor to OcUK - the place I have seen them is anyway
any good electronics supplies store should do them.
However i dont think they would be cheap.
Rapid Electronics - that kinda thing. Im sure you get the idea. Dunno if this could be classed as a competitor as its just for Educational establishments only.
If im wrong however, please remove the name.
