Network Printer always "paused"
1 Nov 2003
Maidstone, Kent
Hi,
I have a Mac Mini (2Ghz Intel) connected to my Netgear ReadyNAS. Attached to the ReadyNAS,via USB, is my Epson C1100 laser printer.
All worked well until I updated the OSX to Snowleopard.
Now, each time I attempt to print from any software (Word, Safari, Chrome etc.) I am told the printer is PAUSED.
This never happened before. I have tried deleting and re-installing the printer but with no luck.
Any ideas chaps?
Thanks in advance
Hussman
I've had a very similar problem when I was setting up a print server using CUPS. The problem was due to the EPSON drivers only supporting USB :confused:
1. Delete the printer (optionally, if you only have this printer press Shift+Cmd+Right-click in the Printers list inside Print & Fax then select Reset printing system...)
2. Download and install Gutenprint for Mac OS X
3. Install the corresponding CUPS+Gutenprint driver for the C1100 with the required ReadyNAS settings
4. Done
Hope that helps :)
Hi,
Thanks for the suggestion.
I tried downloading and installing Gutenprint as suggested.
This went well. However, on looking at the list of supported printers mine, an Epson C1100 Aculaser was not listed.
Help - please!
Thanks in advance ;)
