Hi,
Hoping I can get some much needed help here.
My computer is failing to connect to the internet. It is saying there is no ethernet cable plugged into my computer when there is.
My computer has a wired connection to my router. The router is fine as I can hook up my laptop to it (both wired and wireless).
I have checked to see if its a faulty wire by testing the connection with two different ethernet cables, still no joy. I have also used the same ethernet cable to wire up my laptop to the router (connection worked) so I am sure its not a faulty wire.
Thus I believe it could be my computer?
I recently installed a second hard drive into it about 2 days ago, however it was working perfectly up until last night, when I switched it off for about three hours, I then went to turn it back on 3 hours later and thats when the connection problem arouse.
Any help would be much appreciated!
Its a Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard that I have had since February.
Thanks in advance.
Tom
Thanks in advance.
Tom
