hey guys could really use your help here please, im trying to sort out a local network here at home and its send me freaking crazy.
this is the gear that i have and the end result i want:
my pc = pc1 (xp pro sp2)
dads pc = pc2 (xp pro sp2)
gf's laptop = pc 3 (xp home sp2)
the router that i use is the bt voyager 210.
in my room i have pc1 connected to the 210 via usb
in living room i have pc 2 connected to 210 via lan
pc3 is connected to pc1 via crossover cable
This is all working fine all pc's connect to the internet the problem im having is sharing files from pc1 to pc2.
pc1 can view and use files from pc2 and pc3 (happy with this)
pc3 can view and use files from pc1 (also happy with this)
pc2 can see pc1 shared folder but gets an error msg saying path is incorrect when i try to open.
if i run network setup and set it up that pc1 and pc2 connect to the net via a hub it works fine i can share the files BUT then pc3 gets the error limited or no connectivity and cant connect to the net.
I think the problem im having is a firewall issue but i have no idea how to fix it, let me explain:
running network setup i set pc1 to connect directly to the net and others connect through me (for pc3)
network setup on pc2 to connect to the net through hub
and network setup on pc3 to connect through another pc (pc1)
this all works fine for them all going on the net but like i say pc2 cant see the files from pc1 the only way for this to work is if i disable the windows firewall on pc1 hence why i think its a firewall problem.
if any of you network guru's could possibly help me out on this i would be chuffed. if u need more info please ask away
Thankyou guys
Boo
Thankyou guys
Boo
