Network Problem
18 Aug 2005
Shropshire
Hi all,
I have a rather strange problem with my pc at the moment,
I get access to the internet via a Netgear DG632 ( Router / Modem )
ISP - Wannadoo / Orange
My dads pc has the USB lead from the DG632 and I have the LAN Cable,
Its been working fine for years but today I can't access any online games ( Steam won't connect or COD 4 )
The internet works fine though,..
I've got a static I.P Adress setup aswell.
Can someone please point me towards something I need to adjust to make it work again ??
I've been trying all day with no luck :(
Thanks in advance.
All fixed now incase this happens to anyone else..
I turned off and turned on the router many times but the problem was still there.
So I did a Hard Factory Reset and put all the login info back in and it works fine.
On the netgear you usualy just hold the reset button, but there is a different reset option which clears everything so I'm told, You hold the reset and power back on , then off then on, and voila.
