Hi guys,
Posted a thread a while back saying I had problems with a mates network and after changing ISP from Virgin to BT he is still having the same issues.
Basically when one person is streaming on iPlayer/Youtube or whatever the other cannot use the internet at all! As you can imagine this is a massively annoying issue! I've tried swapping out the Netgear to the Homehub which provided no results, swapped all the microfilters and still no luck?
The weird thing is sometimes everything works fine and you can have two HD Youtube movies streaming at the same time with no isses
Heres the stats from the router:
And speedtest:
In the last hour the pings have been varying wildly and mostly sat at 150-200ms.
Can anyone spot any obvious answers? This is doing my swede in!
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 171939 224163 0 25048 229373 00:19:16
LAN 100M/Full 0 0 0 0 0 00:19:20
WLAN 11M/54M 222088 173404 0 225397 24768 00:19:37
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 32.5 db 16.0 db
Noise Margin 5.0 db 20 db
And speedtest:
