Hi all,
I have recently finished wiring my house with cat6a cable and I have a 1G network switch. I have virgin media broadband and I am currently using the VM hub as my router.
I have a pihole that I am using as my DNS server but I want to add that into the router but the VM hub doesn't let you change the DNS settings.
I have some WIFI issues around the house and I want to change over to 2 or 3 access points instead of the router.
I have been looking at the Ubiquity AC lite access points and the USG or the EdgeRouter X.
What are your thoughts and comments on these systems and do you have any recommendations for the setup?
I don't rely need high speed wireless just decent reliable coverage, if i want high speed i just plug into the wired points.
Thanks
Thanks
