After researching into using two routers together I decided to give it a go, basically I wanted a better wireless signal to my 2 laptops as my main router is downstairs (BeBox Speedtoutch 780) I had a Belkin F5D7633uk laying around, which supports 125Mbps as do the wireless cards in the laptop.
My setup is like this just to give you some sort of an Idea
Main Router ------- (Wireless) X2 Laptops.
| |___ Downstairs Computer
|_______ My Computer Upstairs ***Belkin Router***
Now here is my problem
I reset the default settings in the Belkin router plugged the Ethernet cable coming upstairs into the back then ran another Ethernet cable to my pc, It seemed everything was spot on I had internet access on my PC basically it was all set up and working fine. Now when I try to access the Belkins interface via 192.168.2.1 nothing shows up, I can connect to the Speedtoutch router fine and access the config page etc but I need access to the Belkins settings as the wireless on the router is open and everybody near me can connect to it and use my 15Meg unlimited download speed
I’ve tried to plug the belkin into the pc only but I still can’t connect to 192.168.2.1 somewhere it’s got totally messed up
Sorry if this sounds like gibberish I can’t explain it any better
I cannot get 192.168.2.1 to load up, I’ve even tried the laptop connected directly to the Belkin's wireless and that doesn’t even let me access the config page, somewhere the default gateway of the Belkin has changed and I don’t know what to
Ive just changed all the settings on the Belkin and all looks very promising, I can now connect to the Belkin's config page via 192.168.1.253 just as Zap suggested and everything look all ok.
