Hi folks,
I hope someone can help and my apologies if this is long-winded.
I have upgraded to 2.5gig internet speed. Previously it was 1 gig. My last devices were 1gig capable with a supplier router in modem mode, 1x Honor 3 router and 1x Honor 3 as an Access Point. All was good.
I now have the new supplier router as the main router and the 2x Honor 3's as access points in bridge mode which simply doesn't 'seem' to be working properly. I am aware that they can only be used as 1gig max connections. They are old now and I think I should replace them. When I stand very close to one the Wi-Fi signal is about 50-60% which is why I don't think they are working or set properly.
A diagram of how my home is shown/attached. I want wired devices that are capable of 2.5gig wired to the ethernet switches and knowing that Wi-Fi will max at 1gig.
Should the current setup work? or is there a better way to achieve full Wi-Fi signal at both AP's?
What AP's would you recommend to use? preferably with 2.5G Wan inputs to maximise bandwidth.
Network image link
Thanks for any advice.
Network image link
