Network sharing between specific systems
5 Sep 2020
Hi,
I'm looking for some networking advice. I'm trying to figure out how to set up sharing on a home network, but specificially between certain machines only. I also have the added complication of running different O/S on the machines.
Systems are as follows;
PC A - Ubuntu O/S
PC B - Windows 10 Home
Other Windows PCs on network but not involved in sharing
Desired setup;
PC A to have full access to PC B - essentially this is for file backups I want to push down to it.
PC A to not be accessible to any PCs - for security reasons I only want one-way transfers, and no other access (not even read-only or list).
PC B to not be accessible to any other PCs but A - Other PCs are not owned by me, so should have no access to anything (again not even list or read-only). Unfortunately it's a shared network so I'm looking at ways to firewall/subdivide this in some way.
It's not something I've ever had to look at before or too knowledgable on. The only thing I can think of is using some kind of folder permissions similar to workplace AD setups, but with my particularly versions and different O/S setup I'm not sure it's possible.
It is possible it's just file sharing. All Operating systems supports it between versions.
Thank you. I wasn't sure how ubuntu and MS would interact with each other.
Have I got this right then that it's just a case of adding the user account for A to the files on B, and then removing any general "all users" type access on those files so nobody else can see them? Someone once showed me a c$ backdoor onto peoples systems if you know the PC name - is it possible to prevent that as well?
Yeh but that’s not by default and you still need to set correct permissions.
Just right click folders and set permissions to a certain user as full control then authenticate.
\\hostname.or.ipaddress\share
Username
Password
Should work straight away. Firewall might not need to be setup for file sharing to allow though.
Username
Password
Should world straight away. Firewall mig hot need to be setup for file sharing to allow though.
Thank you. I honestly thought it would be far more painful, at least to keep others out! Will see how it goes this weekend.
