- 22 Jan 2010
In a house with 5 other students, we have a 50meg virgin line. Every bedroom has an ethernet port as well as the living room (7 in total) as well as countless wireless devices; on average there are about 10 devices connected at a time.
At the moment we are using the Virgin super hub, with a D-link DR 615 in access point mode connected to it in order to provide enough lan ports. We have disabled the wireless on the super hub and are using the DIR 615 for wireless (had better signal quality).
It's working ok except for gaming can get laggy. Unfortunately the super hub has no Quality of Service Engine. I was thinking it might be worth buying a new router that will be more capable of managing such a large home network.
What would you recommend for a setup like this? can you get routers with 7+ lan ports or will we still need a second access point? If so should we keep using the DIR 615 or would we be better off buying a dedicated switch? Would this cause problems with a QoS engine?
Sorry for the wall of text.
