- 23 Jan 2006
ok here is the scene.
current installation.
upstairs, modem/4 10/100 port router. 2 machines plugged into it. cable running downstairs to another machine.
all installed cable is cat5e (gigabit compatible? please confirm)
now...I need to go gigabit to allow for faster file transfer from machine to machine.
so, is it possible/can someone point me in the right direction for what I think will work. heres the plan:
current adsl modem/router to be used for just modem.
connect the modem to a gigabit router/switch (not sure which yet, dependant on the rest).
connect all upstairs machines to the router.
connect the downstairs cable to the router
downstairs another router/switch required to connect 2 machines to (is only one machine at the moment)
just trying to get it all right in my head before I go steaming in and order anything.
think I am confussing myself even more here. I really mean gigabit switches, but can I connect the modem/router to a switch, as well as another switch???
thanks in advance.
thanks in advance.
