Like this you mean ?Can you recommend a Network switch with wifi you can turn off please ?
Yes but for about £20Like this you mean ?
L009UiGS-2HaxD-IN | MikroTik
L009 is more than just a router. This product line is up to 4 times faster than RB2011, it has a modern ARM CPU with container support, an innovative enclosure that allows mounting up to four routers in a single 1U space, more RAM, PoE, and 2.5G SFP support. This version comes with 2.4 GHz ax...mikrotik.com
Edit:That One.
I think so I just want to share my internet in the garden room with a few devices.Just a network switch?
Any router will do that, just set it up with an allow list in MAC filtering, everything else gets blocked, this is how I always configure my routers, stops anyone getting on the network even if they did get the wifi password as they are not in the allow list, or did i get the wrong end of the stick ?I think so I just want to share my internet in the garden room with a few devices.
I think you're right. I don't know what MAC filtering is though.Any router will do that, just set it up with an allow list in MAC filtering, everything else gets blocked, this is how I always configure my routers, stops anyone getting on the network even if they did get the wifi password as they are not in the allow list, or did i get the wrong end of the stick ?![]()
How do you currently connect to your internet from your garden room - Are you relying solely on WiFi using your internet router (located in the house somewhere) or, have you got ethernet running to your garden room?I think so I just want to share my internet in the garden room with a few devices.
Within your router, (depending on your router) you should have a MAC filter setting, it usually allows 2 options, 1 block certain MAC addresses only, 2 Allow certain MAC addresses only, every device you have has a MAC address, you should be able to see what they are in some sort of devices tab on your router, you can then add those to the allow list which will stop anyone else connecting.I think you're right. I don't know what MAC filtering is though.
