Network system hardware audit?!
16 Nov 2002
The Moon
Hi all, what is the best way to get all system info and hardware specs of machines on my network without going round 1 by 1 and writing down the CPU speed, ram, hdd space, os version etc?
Is there a free util that can be ran which goes out over the network and fetches this info or is that a big ask?
Spiceworks is the first thing that springs to mind; it will collect all of the hardware specifications of any system it can query on your network. It's ad-support rather than free, though, which may put you off. There are probably many others (hopefully you'll get some more suggestions!).
I'e used Spiceworks before as a demonstration for the type of technology and it worked well. I didn't like the adverts but for free you can't complain
- GP
We use LANSweeper now, it's not too dear and means we have pretty much binned a massive (one of the largest in Eurpope) Centennial implementation off the back of it!
Dameware is pretty great, and not hugely expensive. I used Alloy Navigator at my previous job and it was awesome, but it's also expensive and probably overkill, especially if all you want is the CPU/RAM/HDD of each PC on your network.
I was also going to suggest PSINFO.
How many machines are we talking? If iwere talking a fairly low number and a one off exercise, all you would need is a list of the PC names in a text file, and you can point the psinfo command to the list.
Of the top of my head the command is literally "psinfo @mylist.txt" but don't quote me
www.sysinternals.com
