Hey, I was wondering if anyone could help with a little problem I've been having.
Ever since getting my Xbox Series X remote play (in the same property) to other devices has been flawless ... except for when someone is streaming Youtube or Netflix on another device. Disney+, iPlayer etc is fine however.
Connection speed is 72Mbps, although it shouldn't matter for remote play in the same building.
The Setup is unfortunately using an older BT Smart Hub 1, but its fine for everything except this specific usage scenario. For example .. we can have 4 Netflix streams in 4k perfectly fine for example.
Xbox is wired into the Router, everything else in the house is connected to the 5ghz network (I've split out 2.4 and 5ghz as this causes issues on our FireSticks if they're not separated.
Any suggestions guys? rather not have to invest in a new router unless I have to, but ill consider it as long as its gonna fix the issue.
Cheers all.
-edit-
Would a mesh network likely solve the issues? my gut instinct is not as the signal isn't a problem ... just feels like a load issue as we currently have about 39 devices connected (camera, heating, consoles, fire sticks, phones etc)
Cheers all.
-edit-
