- 26 Oct 2002
- Surrey
Hi chaps. Thought I would ask this on here as chances are some of you will have had experience with this as well. I have done a fair bit of scouting around but I just don't have enough time atm to go through all the manufacturers currently.
Basically I am after a colour laser MFP (printer, scanner, copier, fax), ideally under £500. It is to replace my Laserjet 4300TN and Officejet Pro 8500n with 1 single device to save space more than anything.
One thing that is of extreme importance is Network TWAIN though. Not scan to file, scan to email, scan to ftp etc, direct TWAIN control of the scanning unit over the network. The Officejet Pro 8500n does this perfectly but it simply isn't good enough for business printing. I support a large amount of TS users with 3rd party remote scanning packages and have to have the same environment to emulate/fix problems.
Not sure if this or the networking section was best to put this in but there you go.
Thanks,
Nick
Thanks,
Nick
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
