Network useage meter...
18 Oct 2002
Maidenhead
Is there a piece of software which can give me an overall total of my current network useage. Ie if I was downloading a torrent @ 90kbps and 3 files @ 125kbps, I would like one meter which I can look at to give me a quick total? Router is connected via ethernet btw
Oh, needs to be free too!
Thanks
lay-z-boy said:
netstat and du meter are the best imo.
du meter isnt free is it?
Download free 30-day evaluation version of DU Meter from one of the servers listed below. If you have any problems, please e-mail us with the exact description of your difficulty.
Big Kev said:
Are any of these compatible with Vista, as DU Meter is giving me false readings.
DU Meter monitors all network activity through your computer, so if you transfer a file over the network to another computer then it'll count that as well.
EDIT
I think the only way you're going to get accurate readings on Du Meter or NetMeter is by having your computer connected directly to the internet rather than through a network.
EDIT
But Big Kev, to answer your question, PRTG Traphic Grapher will give you accurate results of the throughput of your router but it's fairly heavy on resources.
