Hi
I have the internet in 1 room.
I want to take it to another 2 rooms, currently the wires go directly into the other rooms and connect to the PCs
I wnat some of those wall outlets (bit like a BT master socket) - where the network wire goes into a room and stops somewhere wiht a box o nthe end. The there is a seperate wire fro mthe box to the PC
What exactly do I need and is it dfficult to connect the network wires to these boxes? or is it similar to connecting an RJ45 socket o nthe end - do i lose any quality by braking up the cable into 2 bits?
cheers
cheers
