hello all,
not sure weather this falls into this or the network section. but i'll post here anyway.
I have a pc with xp sp2. I also have a laptop with vista 32 ult.
Im able to RDP or VNC from the pc to the laptop but can't go from the laptop to the pc (sever edtion installed on both).
I also can't ping the pc from the laptop but can ping the laptop from the pc.
I was reading somewhere that you need the network descovery patch for xp to enable this but i installed it on the xp machine but it made no difference.
In the end i managed to map the c drive of the laptop from the pc using the run box and the ip of the laptop. (workaround)
I have a router sat in the middle, i'm able to see both machines on the dchp client listing.
Seems odd that you can't really network between the two.
(or maybe i'm not doing something right!!! )
