- 13 May 2003
Hi peeps
I have an old house with really thick internal and external stone walls (18” rough stone) and WiFi simply doesn’t not travel through walls.
As a consequence I have set up a D-Link powerline network from the router to 5 locations in the house. My powerline network acts with one WiFI SSID in all locations. This works ok but I find it does drop out occasionally but for domestic use it’s not a problem. Although the powerline adaptor in my study is the weakest probably due to a tortuous path round the electrics.
I am finding however my work Cisco VPN software (which I have no power to change) does not like it. It bounces in and out. I have been using my work mobile as a hot spot but even that seems to be playing up of late, maybe I’ve smashed some download limit.
So I’m planning to get a Cat 5 cable run from the room where the router is along the outside wall to where my study is. Then install network switch in my study so everything there at least can run direct from my router.
First question, can I connect this network switch to my powerline adaptor which is providing the room WiFi?
I am also taking the opportunity to get a Cat5 run from my study to the garage. I currently have my NAS in the study and I’m thinking of mirroring it or relocating it in the garage. I’m also considering adding a POE switch in the garage so if I want to add cameras or an access point I can power them from there.
Second question, can I set up an wireless access point on the network POE that has the same SSID and log on credentials as my powerline network?
Getting a Cat5 and switch to the office is well within my capabilities, after that I’m out of my depth. I just about manage with my Synology NAS because the software is great. The D-Link powerline stuff is basic but works.
Any help much appreciated.
