**Networking Clearance pricing **
7 Feb 2011
Stoke on Toast
Tenda W368R Wireless Broadband Router with Internal Antenna - 300 Mbps @ £9.95 inc VAT
Utilizing advanced MIMO technology, WLAN range is double that of 802.11g products. The W330R also provides WDS (Wireless Distribution System), enabling the bridging of other wireless routers and extending wireless coverage.?
Plenty of features are bundled to better secure and manage a network, including; port and MAC address filters, WPS (Wi-Fi Protected Setup), QoS bandwidth control, and the ability to disable SSID broadcast.? Management from anywhere is conveniently accomplished through a web interface, and a Tenda-developed setup wizard makes installation easy for anyone.
The W368R is the ideal choice for small or home offices in search of a fast, secure, easy-to-use, and feature-rich wireless network.
Specifications
- Standards: 802.11n, 802.11g, 802.11b, 802.3, 802.3u
- Band: 2.4Ghz
- Wireless Rate: 300Mbps
- Interface & Speed: 1 x 10/100Mbps Auto-Negotiation Ethernet WAN ports for WAN connection, 4 x 10/100Mbps Auto-Negotiation Ethernet LAN ports for LAN connections
- Antenna: 2*2dBi Non-detachable internal antenna
- Channels: 11 channels
- Working Modes: Wireless AP, Wireless Router
- Wireless Security: WEP, WPA, WPA2,WPA-PSK,WPA2-PSK
- Internet Connection Type: Dynamic/Static/PPPoE
- DHCP: Built-in DHCP server
- Security: Port/URL/MAC address filter
- Bandwidth Control: WMM
- DDNS: Yes
- Package Contents: W368R Wireless-N Broadband Router, Power Adapter, Quick Installation Guide, One Software CD (User Guide and Setup Wizard included)
Only £9.95 inc VAT.
ORDER NOW
Tenda N6 Wireless Broadband Router - 300Mbps - Dual Band @ £19.99 inc VAT
Connect N6 to a cable or DSL modem and provide high-speed Internet access to multiple computers, game consoles, and media players. Create a secure wireless network to share photos, files, music, videos, printers, and network storage.
Powered by MIMO technology and equipped with 2x5dBi detachable antennas, this router provides superior wireless coverage for larger homes and offices, or for users running bandwidth-intensive applications.
Support for WPA, and WPA2 security standards ensure that you will be able to use the best possible encryption regardless of your other wireless devices. To prevent possible attacks from the Internet, N6 uses dual active firewalls (SPI & NAT) to help protect your valuable data
Concurrent Dual Band
Operates over both 2.4 and 5 GHz bands simultaneously, ensuring top speeds, greatest wireless range, and minimizes interference
Optimal Coverage
MIMO technology helps less "dead spots"to enable consistent wireless signal throughout your home
Streaming HD Multimedia
Provides total combined wireless speed of up to 600 Mbps on both Bands for streaming HD videos, simultaneous downloads, online gaming and other Internet Apps
Secured Connection
Advanced WPA/WPA2 protects your network from intrusion
Simply Encryption
Connect to your secure network simple and fast using WPS( WiFi Protected Setup)
Easy Setup
World's most intuitive utility interface guides you to install a secured network in 3 steps
Intelligent QoS
Prioritizes both wired and wireless Internet traffic to bandwidth-sensitive applications like online gaming, VoIP or stream multimedia
Guest Network Access
Provides multiple SSIDs to create separate networks for guest access
Firewall Protection
Dual active firewalls (SPI and NAT) block any malicious attacks to your network from Internet
Specifications
- Standards: 802.11n, 802.11g, 802.11b,802.11a, 802.3, 802.3u
- Ports: 1 x 10/100Mbps auto-negotiation Ethernet WAN Port, 4 x 10/100Mbps auto-negotiation Ethernet LAN Ports
- Antenna: 2×5dBi detachable antennas
- Functions: MAC address-based access control ,UPnP,DDNS,SNTP,virtual server, DMZ host, ,DHCP server/client,WDS .
- Package Contents: N6 Wireless-N Router, Power Adapter, Quick Installation Guide, One Software CD (User Guide and Setup Wizard included)
Only £19.99 inc VAT.
ORDER NOW
Asus RT-N12E 300Mbps Black Diamond Eco Series Wireless Router @ £20.99 inc VAT
Save the planet and your pocket
Compared with generic Wireless-N routers, ASUS ECO-WiFi CPU reduces 72%* of energy consumption and utility cost
Extended Network Coverage
The RT-N12E features a 5dBi high-gain antenna that boosts the wireless signal, thereby extending coverage range.
Network Map-Manual Free Management
Straight-forward design to help users to:
Display the whole network status and clearly provide WAN/LAN status
Securely connect to your wireless network and prevent intruders from using it
Manage your network in minutes
Try our EZ UI software
• 300 Mbps high speed
• Plug-n-surf CD free installation
• External 5dBi antenna for better coverage
• Power saving: consumes less power during stand by mode
• Support EZ WPS connection
Network Standard: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.3, IEEE 802.3u, IPv4
Data Rate 802.11b : 1, 2, 5.5, 11Mbps
802.11g : 6,9,12,18,24,36,48,54Mbps
802.11n : up to 300Mbps
Antenna: External dBi antenna x 2
*Antenna type will differ according to local regulations and requirement in each country
Operating Frequency: 2.4GHz
Encryption: 64-bit WEP, 128-bit WEP, WPA2-PSK, WPA-PSK, WPA-Enterprise, WPA2-Enterprise, Radius with 802.1x, WPS support
Firewall & Access Control: Firewall: NAT and SPI (Stateful Packet Inspection)
Filtering: Port, IP packet, URL Keyword, MAC address
Management: DHCP
VPN Support: IPSec Pass-Throuth
PPTP Pass-Through
L2TP Pass-Through
WAN Connection Type: Internet connection type : Automatic IP, Static IP, PPPoE(MPPE supported), PPTP, L2TP
Utilities: Device Discovery
Firware Restore
Setup Utility
Ports: 1 x RJ45 for 10/100 BaseT for WAN, 4 x RJ45 for 10/100 BaseT for WAN
Button: WPS Button, Reset Button, Power Button
LED Indicator: PWR x 1, LAN x 4, WAN x 1
Power Supply: AC Input : 110V~240V(50~60Hz)
DC Output : 12 V with max. 0.5 A current
Environmental Operating Temperature: 0 °C to 45 °C ( °F to ºF)
Storage Temperature: -20 ° to 70 ° C ( °F to °F)
Operating Humidity: 10 % to 90 % (Non-condensing)
Storage Humidity: 5 % to 90 % (Non-condensing)
Dimensions: 168 x 124 x 30 mm (LxWxH)
Weight: 210 g
Only £20.99 inc VAT.
ORDER NOW
Edimax AC1200 Multi-Function Concurrent Dual-Band Wi-Fi Gigabit Router (BR-6478AC) @ £44.99 inc VAT
Features:
<ul>
Next generation 802.11ac Wi-Fi standard
3-in-1 Router, Access Point and Range Extender
Backward compatible with 802.11a/b/g/n standards
Concurrent dual-band wireless connectivity for 2.4GHz and 5GHz
5-port gigabit Ethernet connectivity
Revolutionary iQoS for efficient and effective internet bandwidth management
The extraordinary growth in the number of wireless devices found in modern homes has seen a huge increase in demand for wireless speed, range and bandwidth. This continuing trend away from wired connections to wireless communication and the ever-increasing throughput demands of new Wi-Fi devices and applications—including Internet TVs, computers, tablets and smartphones—drives the requirements in today’s homes for high-performance, reliable Wi-Fi to unprecedented levels. To meet the connectivity needs of homes and businesses alike, Edimax has launched the BR-6478AC dual-band 802.11ac router: featuring the latest 11ac draft standard for extraordinary improvements in the speed, reliability and quality of wireless communications.
Next-Generation Wireless Networking
The Edimax BR-6478AC router supports the next generation IEEE 802.11ac wireless standard, meaning higher data rates in the 5GHz band. With 300Mbps speeds in the 2.4GHz band and 867Mbps speeds in 5GHz, the BR-6478AC is ideal for HD video streaming and large file transfers. The router is also backward compatible with 802.11a/b/g/n to ensure compatibility with legacy Wi-Fi devices.
The BR-6478AC can work as router, access point or range extender. Just configure the mode you need for your network environment using the smart iQ Setup wizard.
Concurrent Dual-Band Wi-Fi & Gigabit Ethernet Connectivity
The Edimax BR-6478AC router provides simultaneous 2.4GHz (802.11n) and 5GHz (802.11ac) wireless network connectivity for maximum flexibility of use. Additionally, the BR-6478AC router features four gigabit LAN ports and one gigabit WAN port, offering data rates of up to a staggering 1000Mbps for users with the need for maximum network performance. With gigabit Ethernet connectivity, the BR-6478AC can provide users a fast and smooth media streaming or network gaming experience.
Smart iQ Setup
Features iQ Setup for smart, automatic and quick installation with no CD required.
Edimax’s Revolutionary iQoS
iQoS is Edimax’s solution for a quicker, easier, and more effective way to manage Internet bandwidth. While Quality of Service (QoS) functionality is a common feature in routers across the market, typically only advanced users have the knowledge required to set up the complex parameters. Edimax though has redesigned QoS with user-friendliness and accessibility in mind. A simple and intuitive user interface allows users to arrange bandwidth priority settings in just a few clicks. With iQoS, you can enjoy gaming, video streaming, VoIP applications and BT clients at the same time without the usual nightmare of lag and interruptions. An original, efficient and effective means of managing your Internet bandwidth.
Guest Network*
Supports a guest network to provide connectivity while isolating guests from your primary network.
*Router mode only
WPS (Wi-Fi Protected Setup) Button & Built-In WLAN On/Off Switch
The Edimax BR-6478AC allows users to build secure connections with WPS enabled wireless devices simply by pressing the WPS button - there is no need for the hassle of complex set up and configuration procedures. And with the built-in WLAN on/off switch users can also easily switch on/off the wireless connection without logging into the user interface – an easy way to save electricity when it is not in use.
Only £44.99 inc VAT.
ORDER NOW
ASUS DSL-N66U Wireless ADSL/VDSL Modem Router - 450Mbps - Dual-Band @ £99.95 inc VAT
The ASUS DSL-N66U N900 modem router has up to 900Mbit/s in bandwidth. It is currently the fastest modem router with support for VDSL connections. The DSL-N66U works in 2.4GHz and 5GHz, and uses dual CPUs for optimal computing power towards faster and more stable connections. Wired and wireless networking each have a CPU dedicated to them, guaranteeing improved performance. It also includes two WAN ports (Ethernet WAN and DSL WAN), allowing customers to use it as a modem router or standalone router. Equipped with powerful hardware NAT acceleration and built-in Gigabit Ethernet, the DSL-N66U gives you full Gigabit internet performance, with its WAN and LAN throughput at over 900Mbps.The ASUSWRT interface supports quick setup and simplified network management, while the DSL-N66U also includes AiCloud, the exclusive ASUS cloud computing app.
Key Features:
<ul>
True two-in-one modem router with Ethernet WAN and DSL WAN
Dual system design offers more performance and flexibility for wired and wireless connections
Gigabit Ethernet ports for the fastest, most reliable internet performance
File and printer sharing via two multi-functional USB ports
ASUSWRT dashboard UI for easy setup, signal monitoring, and network application control
Auto-detecting ADSL/VDSL connection with CD/manual-free setup
Finest P2P experience via 300,000 concurrent data sessions
Two CPUs for fast and stable connections
The DSL-N66U offers dual CPU performance and flexibility. Its twin processors each optimize wired and wireless connections. By separating wired VDSL/ADSL and Wi-Fi networking into two compute modules with their own dedicated processing power, the DSL-N66U achieves maximum performance for both connection types with no compromises.
Optimized and Reliable Wireless Coverage via Ai Radar
ASUS Ai Radar intelligently strengthens connections to wireless devices. With high-powered amplification, it provides stronger signals in any direction with better coverage to improve data throughput.
Get online in 30 seconds
Smart auto-detection design makes it possible for you to go from first plugging in the DSL-N66U to setup completion in under 30 seconds! Compared to the lengthy installs and hassles of other routers, this development from ASUS offers a true wonder of ease of use, and puts the most extreme networking speeds within your reach quicker than ever before.
ASUSWRT - Intuitive network setup and control
Easy to use and highly intuitive, the ASUSWRT graphical interface offers complete network management. Gamers and HD media consumers get improved performance with ASUS QoS bandwidth prioritization that prevents slowdown even with other tasks in the background. One-click settings enable easy troubleshooting, plus printer, parental controls, and Download Master all ensure better network productivity and management.
Two WAN ports for DSL and Ethernet offer double the choice
The DSL-N66U has two WAN ports, allowing it to be used as a standalone router when not operating as a ADSL/VDSL router modem. You can choose which mode suits your needs, and in any scenario gain considerable savings and clutter reduction by not having to buy separate power-consuming devices. Whether for a basic home setup or a full wireless network, Ethernet WAN affords the flexibility you require.
Gigabit Internet Browsing with Hardware NAT
Equipped with a powerful hardware NAT acceleration engine and built-in Gigabit Ethernet, the DSL-N66U gives you full Gigabit performance, making its WAN to LAN throughput up to 2-5 times that of traditional software-based NAT Gigabit routers.
AiCloud - Sync. Share. Stream. Your World on Demand
ASUS AiCloud works with ASUS routers to offer the most complete, accessible, and secure cloud platform. It’s a free app for iOS and Android devices, and allows you to easily sync, share, stream, and access all your content from any location. It creates your own private cloud server at home, and connects it seamlessly with the public cloud. Sharing is easier than ever with confidential links, which can be sent via email, SMS, and more. For the most intuitive and flexible cloud access from almost any device and location, ASUS AiCloud is your launch point.
Add external storage, printers, and other devices to your network
Routers can easily become so much more by simply adding the convenience of USB ports, which makes them into multi-role servers. Connect external storage, printers, scanners, and many other USB-enabled devices, and exponentially increase your productivity by sharing resources across your network. No queuing for tasks to complete: get more done at the same time and discover genuine router flexibility.
Optimize Your Network for You
Do you game a lot, or spend most of your time streaming videos? Whatever your planned use is, the DSL-N66U has a Quality of Service (QoS) that lets you select how much bandwidth is prioritized for virtually any task. Plus, the traffic monitor allows you to check your Web usage in a clear and graphical interface.
Separate and Secure Wi-Fi Network via Guest Network Access
The DSL-N66U supports up to three wireless networks over the 2.4 GHz band and three over the 5 GHz band, so it can protect computers from any unauthorized access, hacking and virus attacks. The parental control allows you to set up your kids' computer access times.
VPN Server Enabled
Easily set up a VPN server to surf the Web and access data—no matter where you are. Featuring MPPE encryption, your data transmission will be secure and confidential.
Powerful Online Multitasking at up to 300,000 Data Sessions
Support for a massive data pipeline of up to 300,000 data sessions means the DSL-N66U has around 20 times the networking capacity of conventional routers for exceptionally smooth performance.
Only £99.95 inc VAT.
ORDER NOW
ASUS USB-AC56 Wireless USB Network Interface Card - Dongle - 867Mbps - Dual-Band @ £52.39 inc VAT
The ASUS USB-AC56 is a dual-band 802.11ac Wi-Fi adapter with a USB 3.0 connection that brings high-performance wireless networking support to desktop and notebook PCs. The USB-AC56 features a USB 3.0 connection with support for wireless data rates up to 300 Mbit/s at 2.4 GHz and 867 Mbit/s at 5 GHz with compatible routers. Suitable for use with both desktop and notebook PCs, the USB-AC56 features a dual internal antenna design for great wireless network coverage with minimal desktop clutter and a removable high-gain external antenna that boosts reception still further in weak Wi-Fi signal areas.
Key Features:
<ul>
Next-generation 802.11ac Wi-Fi - up to three times faster than 2x2 802.11n adapters
Selectable 5 GHz/2.4 GHz dual bands increase signal clarity for better HD multimedia
AiRadar technology provides a stronger signal over greater distances
External high-gain antenna for 150% stronger Wi-Fi signal
USB 3.0 connection for high-performance wireless networking with desktop and notebook PCs
Next gen 802.11ac wireless, up to 3X faster than 2x2 wireless N adapters
The fastest Wi-Fi ever becomes more accessible via USB, going up to 867 Mbps on the clear 5 GHz band. Using 802.11ac wireless, faster connectivity and enjoyment come to all your devices. Compared with current 802.11n, the USB-AC56 delivers up to 867 Mbps at 5 GHz, which is 3X faster than 802.11n!
Maximum flexibility for maximum wireless coverage
The USB-AC56 wireless-AC1200 USB adapter can cover larger homes and offices, including multi-floor locations. Its detachable high-gain external antenna and strong dual internal antennas provide ample transmission power for bigger areas. The detachable antenna can be removed to reduce power draw and emissions should medium-range coverage be sufficient. It can also be upgraded with a more powerful antenna if needed.
Intelligent signal management for stable wireless connections
ASUS AiRadar intelligently strengthens wireless device connectivity using precise directional signal amplification for extended coverage, increased data throughput speed, and enhanced stability. Because connection strength varies based on your environment, the USB-AC56 Dual-Band Wireless-AC1200 USB wireless adapter uses two internal antennas and an external high gain antenna and high-powered beam packing to detect wireless router locations to shape transmissions so they’re optimized for the fastest, most stable connection strength.
USB 3.0 for full 802.11ac performance
USB 3.0 allows the USB-AC56 Dual-Band Wireless-AC1200 USB wireless adapter to pair with notebooks and desktops using a bandwidth up to ten times that of USB 2.0. It means the full advantage of 802.11ac networking is realized, as the adapter has enough throughput overhead to support much faster network speeds.
The USB-AC56 also includes a desktop cradle with a three-foot cable for more flexible positioning in troublesome Wi-Fi reception areas.
Only £52.39 inc VAT.
ORDER NOW
Asus USB-BT400 Bluetooth 4.0 USB Adaptor @ £8.99 inc VAT
- Most advanced Bluetooth 4.0 adapter, backward compatible with Bluetooth 2.0/2.1/3.0
- Enables wireless communication with Bluetooth-enabled computers, printers, phones, headsets, speakers, keyboards, controllers, and more
- Bluetooth Low Energy technology for energy-saving wireless connectivity
- Highly portable ultra-small design
New generation Bluetooth 4.0 for versatile wireless connectivity
The USB-BT400 is a Bluetooth Smart Ready USB adapter with new Bluetooth 4.0 capabilities. It connects you with a multitude of compatible devices and supports Bluetooth Low Energy (BLE) to reduce power consumption. In dual-mode, the USB-BT400 maintains full backward compatibility with Bluetooth 3.0, 2.1, and 2.0.
Get Bluetooth 4.0 and connect with multiple devices
The ASUS USB-BT400 provides new and advanced Bluetooth 4.0 and enables wireless connectivity with a wide range of devices such as computers, printers, phones, headsets, speakers, keyboards, controllers, and more. In addition, the ultra-small USB-BT400 comes with Bluetooth Low Energy (BLE) technology, which lets you enjoy energy-saving connectivity.
Only £8.99 inc VAT.
ORDER NOW
Asus PCE-N10 Network Adapter 150Mbps - PCI Express @ £11.45 inc VAT
• WPS(Wi-Fi Protected Setup) - Quickly set up a secure wireless connection.
• Software AP - Connects your notebook and game consoles to the Internet.
• Supports WEP, WPA-PSK, and WPA2-PSK methods for enhanced security.
For quickly setting up a secure wireless connection. Press the Hardware WPS button on PCE-N10 about 3 seconds, then press the WPS button on ASUS routers as well. Either you can choose to use software WPS, enabling the WPS utility in the WPS Wizard interface. And finish the setup with 3 steps.
Software AP
Software AP mode allows the WLAN card to act as a virtual access point. The computer needs to be connected to a wired network using an Ethernet connection in order to provide network access to WLAN client.
Comes with a Low Profile bracket included in the box
Only £11.45 inc VAT.
ORDER NOW
Devolo dLAN Powerline 1200 Plus with WiFi AC (Gigabit Ethernet) Single Pack (9385) @ £95.99 inc VAT
<iframe width="560" height="315" src="//www.youtube.com/embed/bxy2nfcQiJQ?list=UUP5BTJ9LEnkLB_ZJmVX65xQ" frameborder="0" allowfullscreen></iframe>
Features:
<ul>
The best home network connection, thanks to Powerline Technology. WiFi from any electrical socket. Simply unpack it, plug it in and get started.
Finally WiFi at ac speeds: Up to 1200 Mbps for smartphones, tablets, laptops and other devices.
Four integrated antennas ensure outstanding WiFi ac reception.
Simultaneous use of 2.4 and 5 GHz WiFi frequencies for maximum WiFi speed.
Powerline connection over the electrical wiring at speeds up to 1200 Mbps.
For the fi rst time, devolo range+ Technology is taking advantage of all three wires in the electric mains circuit at the same time for even more performance and longer range.
Featuring two integrated Gigabit LAN ports for your Internet compatible devices (Smart TV, game console, computer, etc.).
The integrated electrical socket ensures that no power socket in the room is wasted.
WiFi Move Technology automatically connects multiple adapters to a single WiFi network. Optimal WiFi reception throughout your home—entirely automated.
Integrated encryption at the push of a button! 128-bit AES for the Powerline connection and WPA2 for WiFi ac.
It works throughout your home thanks to automatic phase shift.
The intuitive devolo app helps you perfectly manage your personal home network to meet all your needs (e.g. child-safety features, guest accounts, WiFi time control).
Compatible with all adapters of the 200/500/650/1200 product series.
Rely on number 1: More than 20 million devolo dLAN® adapters have been sold worldwide.
Complete 3-year warranty.
Only £95.99 inc VAT.
ORDER NOW
OcUK Professional Cat6 RJ45 5m Network Cable - Blue (B6-505B) @ £2.50 inc VAT
Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250 MHz.
- 5 Mtr
- Blue
- UTP (Unshielded Twisted Pair)
- Cat 6
- Moulded Snagless Boot
- 24 AWG X 4P
- ETL/3P VERIFIED
- ISO/IEC 11801 & EN 50288 & TIA/EIA-568-B.2-1
Only £2.50 inc VAT.
ORDER NOW
OcUK Value RJ45 1m Network Cable (URT-601) @ £0.89 inc VAT
OcUK Value 1m RJ45 Network Cable is perfect for use with any home or business network. Offering you the ability to transmit data between network devices of speeds upto and including Gigabit (10/100/1000), this makes it the perfect addition to you home network infrastructure.
This cable can be used to connect any network device to another. How ever this cannot be used to connect two computers together without the use of a network switch.
- Grey in Colour
- Speeds upto and including Gigabit 10/100/1000
- Perfect in conjunction with 10, 100 and 1000 Base-T networks devices.
- Gold plated connections to ensure clean transmission of data across your network devices.
- Used to connect network devices together through a network switch (i.e. modem router, switch, access point)
- 1 Year Warranty
Only £0.89 inc VAT.
ORDER NOW
OcUK Value RJ45 3m Network Cable (URT-603) @ £1.30 inc VAT
OcUK Value 3.0m RJ45 Network Cable is perfect for use with any home or business network. Offering you the ability to transmit data between network devices of speeds upto and including Gigabit (10/100/1000), this makes it the perfect addition to you home network infrastructure.
- Grey in Colour
- 1 Year Warranty
Only £1.30 inc VAT.
ORDER NOW
I need a replacement for my horrible virgin home hub, something where I can limit DL when I play and my roommates decide to download so I can alt tab/limit to 1 Mb and play like a baws, will any of this do ? :D
you need a router that enforces QOS
The tenda one for 19.99 does do it and you can set it up like that there are much more expensive options that will do it better but they aren't in the clearance deals.
Yeah I use my Virgin Super Hub in modem mode and have an Asus N56U Router and use that for all the house PCs via ethernet and the tablets via wireless
Do need a better router than the crappy tesco one I have, that's for sure.
What is the Asus like compared to the Tenda? (aside from looking like the kind of router batman would have)?
What about the asus for 20 quid ? never heard about tenda brand so I am a bit suspicious :)
