Networking headbanging!
18 Oct 2002
The Land of Roundabouts
Bit of a weird one this!
Got a new install of CentOS that is unable to ping the internet, dns does resolve an IP and i can ping internal devices ok. Its purely external IP's that fail to ping.
I hear you shouting "no gateway set" or "bad routing table" :p
And i'd say the same, except the route is set as follows
Code:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.100.0   0.0.0.0         255.255.255.0   U     0      0        0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U     1002   0        0 eth0
0.0.0.0         192.168.100.253 0.0.0.0         UG    0      0        0 eth0
ifconfig output
Code:
eth0      Link encap:Ethernet  HWaddr 00:19:DB:6F:55:0E
          inet addr:192.168.100.38  Bcast:192.168.100.255  Mask:255.255.255.0
          inet6 addr: fe80::219:dbff:fe6f:550e/64 Scope:Link
etc
The machine is set with a static IP address.
Anyone got any more ideas? I'm not to great when it comes to routes etc and I'm pretty much stumped.
Would have thought your routing table would have looked like this as all my server are almost the same
Code:
192.168.1.0  *             255.255.255.0  U     0      0      0 eth1
default      my.host.com   0.0.0.0        UG    0      0      0 eth1
check in /etc/sysconfig/network
you can set the gateway there alsoe with GATEWAY=<ip address>
Code:
[root@Hades ~]# cat /etc/sysconfig/network
NETWORKING=yes
HOSTNAME=Hades
GATEWAY=192.168.100.253
Already set :)
I was expecting "default" and wildcards in the route table as well, strange that its not, it was set using
route add default gw 192.168.100.253
As well as defining it in the config files
I've got a feeling its going to be something as simple as that though!
Restart / rebooted and reinstalled all no joy! Extremely frustrating! :)
Just an observation
I've never noticed this before. the difference between specifying "-n" when running the route command
Code:
[root@Hades ~]# route
192.168.100.0   *               255.255.255.0   U     0      0        0 eth0
link-local      *               255.255.0.0     U     1002   0        0 eth0
default         192.168.100.253 0.0.0.0         UG    0      0        0 eth0
[root@Hades ~]# route -n
[root@Hades ~]#
ok so from the box can you ping the gateway? As thats an internal address from your previous post it should be fine if not and you can ping other internal addresses maybe worth looking at the gateway :)
Eureka
Pesky firewalls! we define rules against ip address's, this particular address was in a range that was set to deny icmp traffic (as well as ssh) :rolleyes:
Ping was never gonna work :o:D
I had corrected the problem this morning but my choice of using ping to test it was what sparked this thread. Lesson learned and only half a day wasted :cool:
Thanks for the input!
