- 31 Oct 2005
- Leeds
Hi there, just got my laptop back from ITSS (I believe they repair the teachers for schools laptops..
Anyhoo the laptop will connect via wireless to my network, the internet gateway says the "internet is connected"
When I hover over the wireless connection is says I'm connected at 54mps
However the gateway connection shows 2mps
Also when I try to use IE or FF to go to a website, the web bar displays 10.0.0.1
I've tried the Winsock fix, I've looked to see if the laptop is set to obtain IP addresses automatically, there is no conflict between any other devices
I have also unistalled the windows gateway
Nothing has worked
I have also tried using a network cable, to the same problem, the internet gateway shows a connection speed of 2mbps
Would love some help or areas to look into!
Cheers
Running XP
Nothing has worked
Cheers
Running XP
