Howdy folks.
Am in a real pickle of a situation atm with my network i have, its tricky to explain so i did a drawing lol and i hope it helps.
Heres the deal, I have My main PC, My mams PC, and my xbox 360. There is one network card in my pc and one in my mams pc and the correct crossover cable linking them up, i also have the cable given for the xbox360 that goes to my pc but is not plugged in when my mams pc is on. So when i want to use the 360 i unplug my mams cable and plug the xbox in and when me mam wants on i unplug the 360 and plug her cable in, hopefully your still with me.
heres a pic of the set up
So basically my setup was all working fine one week ago, then suddenly on the weekend something happened, i dunno what because i wasn't here but the network just stopped working. Now i got my xbox360 back working again but the network between my pc and my mams just doesn't work.
the network is on, the cable works both cards are working and the green light is on, on them. and the connection even comes up in the task bar as being on ie - its not saying the cable is unplugged etc.
but for some reason the connection just isn't going through, i can access the net and everything on my pc but i can't on my mams pc.
heres where it gets sticky, i can't ping either i can't ping a machine when i'm on the other the machine i just get this.
so basically its not picking the other machine up whatsoever, and vice cersa when i try and ping my machine from my mams machine.
I go into the LAN connection properties etc and heres my setup
my mams machine is almost identical except with 192.168.0.11 as its ip.
Like i say the xbox works perfectly and still does and its the same kinda netowrk thing so i dont no whats going on with my mams machine.
I have no firewalls on either of the pc's so nothing is blocking the connection at all.
ANy help would be fantastic because me mam is doing me nut in harping on about this not being fixed within 5 secs of breaking.
G
G
