Folks,
I'm at the point now of contemplating setting fire to my PC. I have;
AMD Phenom II X6 1090T
Asus Crosshair III
4GB Corsair DDR3 running at 1333MHz
60GB SSD (OCZ Sata II)
Blu-Ray read and write
Couple of Sata II 3.5 disks
Windows 7 Ultimate 64-bit
So it was set-up in November 2010 and has run just fine with my BT HomeHub 2 over ethernet. About a month or so ago, I tried the HH3 and I could not browse any web sites, click the browser and it struggled to display content, despite Windows 7 reporting I had an internet connection. Thinking it was faulty, BT sent me another (Type B again) and this did the same. I used the same ethernet cable and plugged this into my laptop running Windows 7 Ultimate 32-bit and it connected fine and I could browse the internet so at the time this kind of proved the ethernet cable and router was OK but something was wrong with my desktop PC. Foolishly, I re-installed Windows and it made no difference. When I plugged my HH2 back in, all worked OK.
Then, the HH2 modem packed up so I thought I would try a third party router and got a Netgear N300 (2200) a few days ago and whilst this can connect to BT broadband, it exhibits the same fault the HH3 did when I try and browse the internet on my desktop, i.e, nothing is displayed, pings to websites return nothing. Again, I connect my laptop using the same ethernet cable and it works fine.
So I'm starting to realize, for some reason, my PC is to blame. I have even tried a new Intel network GB card and disabled the onboard realtek GB controller. Still exhibits the same problem.
Does anyone have any suggestions? I have never seen anything like this. Because the HH2 packed up, I basically can't now connect via ethernet from my desktop PC and am using a laptop via wireless as this seems to work OK.
I just can't understand the problem. Can a particular version of Windows cause this? Could the motherboard be faulty? It was odd that HH2 worked (when it did) and the HH3 had routing problems.
Asus Crosshair III
) I was having network problems with (Windows 7) so I guess this proves it is something to do with Windows 7?
