Networking problem
18 Oct 2002
Ledbury
This one's an interesting one, and isn't helped by the fact that the person that phoned me (uni friend) is 3hrs away! Anyway, she basically has no internet, and needs to sort it out :)
My problem is i can't tell if she's actually understanding what i ask her, and whether she's doing the right things! The setup is a linksys router connected to a BY cable modem, and all the computers are wireless.
Apparently the correct lights are on on the router and modem but it suddenly stopped giving them internet. So i asked if she was connected to the network properly and she says yes, so i ask her to bring up the router admin thing in IE... 'page not found'. So clearly she's not on the network, BUT the computer says it is (network connections say connected), BUT ipconfig gives no IP addresses!
The router/modem have been turned off and on again which has made no change.
So, what should i suggest she tries? Other than finding someone who's not 3hrs away to have a look!
If the router is reset (ie. back to factory settings), are there any bits, other than wireless security, that need setting up for it to work with a BY cable modem?
Thanks
