I would have been more specific with the title but I didn't know what else to write!
I've had a look through the stickies and I don't think they have the answers I'm looking for.
In preparation for when I get my Wii on Christmas day, I'm trying to sort out some way I can get it connected to the Internet. There is currently one computer downstairs which connects to the Internet using a USB modem. Then there is a crossover cable connected to the downstairs computer which goes all the way upstairs in to my computer so I can have access to the Internet with my PC. To do this ICS needed to be set up. Now I have a wireless access card connected to my computer which I want to create some sort of software access point (SoftAP) with. It's with this that I want to connect my Wii to. Now for some reason I can't seem to get my computer to direct the shared Internet connection it is receiving to the SoftAP so a device connecting to the SoftAP can use the Internet. At the moment all I have is a Nintendo DS and a copy of Mario Kart to test the connectivity with, but I'd imagine this would be the best thing to use anyway as I'd guess a DS's and a Wii's wireless infrastructure would work pretty much the same.
If that sounded a bit confusing I've tried drawing a picture of what exactly I want to do. Even though my Paint skills aren't exactly what you'd call anything decent hopefully you will be able to see what I mean.
I use the Asus software that came with the wireless card, but I also have the option to use Ralink's software (from my understanding the card is an Asus branded Ralink card).
I believe what is causing the problem is that my computer is already using ICS to connect to the Internet and for some reason will not relay this connection to the wireless SoftAP. I've tried setting up a SoftAP using the Asus software with my Ethernet card as the Internet connection, but this doesn't seem to work. I've tried manually bridging the Ethernet and Wireless cards as well but to no success. After a search on Google I though that maybe setting up an Ad-hoc network would solve my problem but it does not (I do not know what one is to be honest)!
So basically I've tried everything I can think off, but still cannot get this setup to work. In theory it seems very possible but in practise the problem is a little more complex than it sounds.
Before someone says "Just buy a router", well that would have course be easier, but it isn't really an option. This would only be a temporary solution until I go back to my Uni house where we have a wireless router, so I don't want to be investing in any extra equipment.
Thanks in advance for any helpful replies.
