Hello,
I'm using an orange livebox to connect to the internet, it has 2 LAN ports and I want to have 4 or 5 pc's plugged into it total.
So I'm using a WRT54G as a switch.
Livebox = 192.168.1.1 and has DCHP enabled.
Linksys = 192.168.1.2 which dchp disabled, upnp disabled, and is plugged in to the livebox ( wich a ''switch'' port, not the ''internet port''.
My pc is 192.168.1.11 which is assigned by dchp, plugged directly to livebox everything works.
Dads pc is 192.168.1.110 which is manually configured, plugged into linksys and works fine with internet acces n stuff...
Mums lappy wich is connected by wifi with the linksys with wireless G and WEP, dchp assiged her 192.168.1.10, everything works perfectly.
Now, until now everything worked properly and all pc's could connect to each other and the internet.
But when I add:
Mums pc, dchp assigned 192.168.1.12, over WIFI, with WEP to linksys.
The network is still fine, but, all pc's lose internet connection
All pc's can still contact the livebox on 192.168.1.1 which says it's still connected to the internet. Called isp and they say they got normall contact with the livebox.
Rebooting the livebox makes me have Internet again for 10 seconds on ALL pc's after which the same thing happens, all pc's no internet connection.
Nothing happens when I disconnect my mums pc from the linksys.
Only way to regain proper net is to have my mums pc disconnected from the network and reboot the livebox.
Any ideas what on earth is happening ?
How can I get my mums pc to have internet/ network conenction without messing it up for all pc's.
It's just odd:
Livebox has internet connection
all pc's have connection with each other and the livebox.
But all pc's dont get internet, it's just plain odd.
Anybody has an idea how I can fix this ?
But when I add:
.All pc's can still contact the livebox on 192.168.1.1 which says it's still connected to the internet. Called isp and they say they got normall contact with the livebox.
It's just odd:
