New £1000 gaming build
26 Dec 2009
London
Looking to buy a new gaming rig for about £900, the less I can spend the better. Most of it will be for gaming and desktop publising. No overclocking.
Looking at getting the following:
Intel Core 2 Quad Q9550 2.8GHz
Asus P5E Pro.
Corsair TX 750W ATX SLI Compliant Power Supply (CMPSU-750TXUK) (future proofing, cos its got 4PCIE connections)
OCZ Obsidian 4GB (2x2GB) DDR3 PC3-12800C9 Dual Channel
Sapphire ATI Radeon HD 5870 1024MB GDDR5 PCI-Express Graphics Card
2 500GB AAKS WD HDD's
1 Optical Drive from Sony
Storm Scout Coolermaster case.
Or
i5/7?
For a thousand pounds you should be getting intel i5. Intel socket775 has been replaced.
Just change the CPU to a i5 750.
and pick a new motherboard. The rest of your components are sweet..!
A corsair 650HX psu is modular version, will be easier to wire the case with only what you need to use.
AMD is a option, cheaper, but a good intel i5 system will always be faster.
something like this?
go for the 5850 and just flash it to hit 5870 speeds :)
comes out at £850 leavingyou enough for a nice Benq 24 inch monitor :)
EDIT get the retail version of the i5 chip so you get a heatsink,
alternatively theres an i7 prebuilt on this week only, well within your budget. http://www.overclockers.co.uk/showproduct.php?prodid=FS-030-OE&groupid=43&catid=1444&subcat=
Trouble with that modular is it is only 650w, and I believe corsair 650w is only 2 PCI-E? My TX is. The 750w has a bit more room for growth and xFire.
