New 24" replacement
5 Mar 2007
Hi -
I've had an OC value 24" monitor which has been fine, for the last 18 months, but it suddenly gave up on me a couple of days ago. I'm feeling a bit richer now and thinking of getting a higher spec monitor so I was wondering if anyone had any personal recommendations. The one I had thought of was the Samsung T240. Anyone got better ideas? :)
Hi -
This:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-028-NE
gets a lotta loving around here.
tough one going from a DGM, it offered the right mix of colour accuracy, black level and response times that would be hard to beat by any monitor im sure. on image quality alone my DGM is the best all round 24" screen ive used
+1 you need 2ms response time if your spending a lot on a monitor for gaming
In my opinion, it actually depends whilst playing a game whether you are looking for ghosting or not. If you aren't, the chances are you will not see it at all, or if you do, it will be very little.
