Hi guys, making a post for a friend of mine who is waiting for forum registrataion to come through.
Received a new 2407 from ocUK today and seems to have a slight problem. Here are is specs.
AMD 2400+
1GB RAM
Sapphire ATi x800 Pro [AGP]
DVI connected.
Catalyst 6.5
XP recognises the monitor as the 2407. Drivers are installed from the supplied disk.
Same on all resolutions.
Problem is:
When I move something over a white background, I see 'green ghosting' folowing the movement, very little mind you but noticebale.
Likewise if I move a window then I can see the ghosting.
However, if I play a game then I do not appear to see it. The same goes for playing DVD's!
I've swapped the DVI cables and it's still the same.
I've played about with the settings, brightness etc and I would say there was actually a difference but the ghosting still seems to be present.
When I scroll webpages it's also ghosting, but it depends what is displayed on the screen.
In WMP 10 when I scroll down my library, the ghosting is no where to be seen.
I have changed the res. and ghosting is still there.
grateful for any help/advice you guys can give.
AMD 2400+
1GB RAM
DVI connected.
Catalyst 6.5
Problem is:
