Right guys 'n' gals (must never forget the ladies),
I am after a 27" monitor. My priority is picture quality and I will be:
1st) Gaming
2nd) Work (office etc etc)
3rd) Movies etc
My budget is £700
I was looking at the Samsung SA27A950D but my colleague did explain to me that although, lovely that it looks and it's fast, it has the same res as my 23" NEC (1920x1080) and that a higher res (2560x1440) would be of more benefit. My gfx card is the POV GTX590 TGT Overclocked and Watercooled by AquaGFX so the higher res should be ok. He also is not a fan of reflective screens and he mentioned that the Sammy has a very reflective screen. I'm using an NEC EA23WMI IPS at the mo but as I have just started to game (BF3 and soom MW3) it just cant cut it at high speed.
Any and all advice is appreciated.
Chris
1st) Gaming
3rd) Movies etc
My budget is £700
Chris
) so I would suggest you think how practical you find the 1920 x 1080 resolution of your existing monitor before deciding whether the 2560 x 1440 resolution would be desirable. You certainly have the graphical horsepower to make a go of the 2560 x 1440 resolution but equally you would see great benefit in terms of responsiveness by going for a 120Hz monitor. It makes an absolutely massive difference on games such as Battlefield 3. If you haven't already checked out the S27A750D linked to on
). Do you have any tips on set up? And most importantly, thank you for your time.
