New 2nd monitor only running at 60hz?
17 Jan 2016
Valley of Jade
I recently bought the AOC G2460PF 24" to replace my old 1080 second monitor.
The old monitor used hdmi. But this new one can use DP and is advertised at 144hz. So I used the DP but the monitor is running at 68hz according to its monitor menu.
Is this some kinda bug, or is there a way to change this?
The part in the menu tells me the hz but doesnt give me options to change it. Nvidia still reports it at 60hz, like it thinks its my old monitor.
Have I come across a roadblock here and the new monitor is being recognised by nvidia as the old one? I've noticed that changing the color settings in the nvidia panel as no effect on the new monitor.
I know the new monitor is freesync, but I thought I'd at least be able to manually control the refresh rate?
Anyone any ideas?
I found a work around or fix. I went in to display adapter settings in windows, selected the monitor tab and was able to set it to 144hz there. Then the monitor was reporting correctly the 144hz setting.
