Have you tried running your PC on its side? The 3080 is quite heavy and it might be sagging enough to break contact.
That has certainly crossed my mind yes, would wait for 3rd party reviews but they look like strong cards. Questions around their Ray-Tracing perf tho.. will wait and see 3rd party reviews.
Looks like the consensus is dead card, thanks the help though all, very much appreciated.
So I'm writing this with the 3080 working! Absolute shout on the GPU sag thankyou so much! Without the support bracket the card looks to be mounted correctly (it clicks in and doesn't look to sag to much at all) but when I laid it down and unscrewed it so it freely rests in the slot.. bingo it works. Installed the sag bracket messed around for an hr or so and all is well.
Wonder if my motherboard (being a bit old and certainly not top end) has some iffy connections as I see loads of others not using the bracket without issue.
Thankyou so much for all your help, what a great community!
Did the fan start when sag? Mine not working top, i've tryed everyting
