- 23 Feb 2009
- South Wirral
Solved: New 4970K build and won't start up. Gigabyte Z97X-SOC Force motherboard
I am having problems getting a devil's canyon build to start up - I can't even get to a BIOS screen. It is stuck in a loop of powering up, stays on for about 5 seconds, then powers down ... then repeats this cycle until I switch off at the PSU. The fans all spin up as does the CPU cooler.
I have gone through Huddy's very handy troubleshooting guide and am not getting anywhere.
Components are:
Intel i7-4790K cpu with stock cooler
Corsair AX760 power supply
Things I've tried:
- All power connections reseated - many times ! The PSU works fine as I had it on a different build not long ago.
- Reseated the CPU
- Only a keyboard connected. There are no drives or cards.
I am using the on-board graphics and tried DVI and HDMI connections.
Just before it powers down, the status code on the MB display is C0 - which is just listed as "reserved" in the manual - so no help there.
I'd be grateful for any suggestions as I am stuck at the moment. It is particularly annoying as this is the build I wanted to watercool once at the workshop tomorrow.
Components are:
Things I've tried:
- Reseated the CPU
