Ok I want to build a 5870 based gaming PC but I'm very sensative to noise and want it to be as silent as possible as i'll also use the pc for work.
1) Will the Sileo case be ok and fit the HD 5870 and the Noctua CPU cooler without any problems?
2) Is it easy to replace the stock case fans with the noiseblocker fans?
3) Should I use Noctua fans instead of Noiseblocker ones?
4) Will I be able to get a decent overlocker with the above system?
And if anyone has any better alternatives please let me know.
![newspec.jpg](http://img225.imageshack.us/img225/8011/newspec.jpg)
